4 channel to 3 channel
Old 02-21-2015, 12:59 AM
210guy's Avatar
Default 4 channel to 3 channel
I installed a 3 channel moser 12 bolt and was wondering if theres a new harness I have to buy in order for abs to work or can i just use the old harness and plug one of the two connectors to the top of the center section?
Old 02-21-2015, 07:15 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
You reuse the exiting harness. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 02-21-2015, 10:02 AM
210guy's Avatar
Awesome thanks for the help bob
Old 02-21-2015, 03:00 PM
210guy's Avatar
Hey bob, does it matter which side I use? Plugged it in and still have the abs inop light on
Old 02-25-2015, 07:10 AM
LS1Tech Sponsor
I misread this when I told you that you reuse your harness. I initially thought you were just wanting to reconnect your 3 channel harness up to a Moser 12 bolt with ABS. I just now caught the title "4 channel to 3 channel" I take it your car is/was a 4 channel, and you're attempting to convert it to a 3 channel? If so, I'm not sure what you can do as if I recall they use a different ECU. Bob
__________________
Old 02-25-2015, 08:08 PM
210guy's Avatar
yup car was 4 channel but the 12 bolt i got was 3 channel. so i guess im **** out of luck ha oh well as long as the brakes still work right?
thanks for the help, Mike
Old 02-25-2015, 08:12 PM
LS1Tech Sponsor
Yes, the brakes will still work just fine. You won't have ABS up front or in the rear, which is the way I prefer them anyway. If you slam hard on the brakes you'll lock them up, so you'll have to use threshold braking. Bob
__________________
Old 02-27-2015, 11:35 AM
LopeyZ's Avatar
You could get 4 channel axles and backing plates like your stock setup. That is the easiest approach. Actually converting to 3 channel is possible but a much more involved process.
Old 02-27-2015, 11:49 AM
high n dry's Avatar
Don't u need to change the abs block out??? I just pulled mine, it has 1 less brake line than 4 channel. Let me know if u need the abs block for 3 channel.
Old 02-27-2015, 12:08 PM
LopeyZ's Avatar
You can attack this problem that way but it's only 1 small part of the puzzle. There is a lot more too it than swapping the module.
Something else to consider is that the 3 channel rear will need 4 channel brake lines to hook up to the existing system.
Old 02-27-2015, 06:03 PM
210guy's Avatar
Sounds like too much work lol and ya I used the same brake setup from the 4 channel.
Old 02-27-2015, 08:39 PM
LopeyZ's Avatar
Then get you some 4 channel Moser axles and you are in business.
Quick Reply: 4 channel to 3 channel
