Trans temp sender
I'm assuming you have an A4. On my A4 I drilled and tapped the side of the pan using a B&M pan plug kit. Also on the drivers side of the A4 (I believe it's half way up the tranny) their is an 1/8"NPT test port that the sender will screw right into. This spot is know to give an accurate reading too.
I did a search for you in the "automatic Transmission" section of the forum.
https://ls1tech.com/forums/showthrea...ns+temp+sender
