Cooling Fan PCM Grounding
1998 Z28. Cooling fans stopped working. I have narrowed it down to: a bad ECT sensor, a bad wire from the sensor to PCM, or a bad PCM. Going to switch out the sensor and do a continuity check on the sensor wires tomorrow. I have physically unplugged the fan relay signal wires from the PCM and grounded them and the fans work. My question is: all of the fan wiring diagrams show the PCM grounding the fan wiring system to activate the fans after receiving a signal from the ECT sensor, is the grounding actually done internal in the PCM or is there another relay somewhere that physically does the ground switching?
