Turbo manifold, battery box, gauges, K&N, 98+ rear brakes
Category: Accessories
Price: $100
Part Fits: 93-02 Chevrolet Camaro
Location (State): IL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
1) Carbon fiber grill 98-02 camaro. Condition is a 9/10 some very small rock chips only noticeable from a foot away. This includes mounting hardware. Grill is blank (no "camaro" or "RKsport")-------SOLD
2) Moroso Battery box part number 74050. JUST THE BOX AND CLIPS FOR THE LID. Nothing else included.........$35
3)Shurflo water pump part number 2088-422-444. This pump has never been used. Planned to use it for a A2W intercooler set up but went A2A.........$50
4) 3" ID exhaust flex section. New, total of 12" long..........$20
5) 38mm to 44mm steel wastegate adaptor. Never used...........$25
6) 4th Gen F-body Drivers side turbo manifold. This looks to be a home made copy of the kit that uses a stock pass. side manifold and wraps under the motor/trans to join with this drivers side manifold which hangs the turbo in front of the motor (up high on the driver side). The geometry of the manifold looks good, the welds are pretty ugly. Looks like an amateur mig job. A couple hours with a grinder (inside and out) and you would have a nice start to a kit. Please do your own research on this kit. T4 flange, 38mm wastegate flange. ...................$200
7) Stock Pioneer 12 disk changer. Worked when removed a couple years ago. Removed to locate battery in its spot. Includes disk tray.........$20
8) K&N RE-0870 air filter. New, just a hair too big for my turbo setup. Still in plastic. 4" inlet, 9" long. ..........Sold
9) Autometer narrowband A/F ratio gauge...............$20
Autometer electric fuel pressure gauge NOTE: this is the older style that requires the sensor and a little black box for interpreting the signal, neither of which are included..........$20
10) 98-02 Camaro rear brake calipers. These came on my 9" and I have no use for them. They look a little beat up due to the shoddy paint job. What you see is what you get.............$50
