8.8 with LS1 brakes
Old 03-01-2015, 08:38 PM
All Pontiac WS6's Avatar
Default 8.8 with LS1 brakes
Has anyone used the LS1 rear brakes on an 8.8 ??? I would like to use the long axle on both sides. Using the two long axles would narrow the rear end 3". That said it has the Ford Explorer tube ends. I am not sure what to do about my brakes. Thanks, David
Old 03-02-2015, 02:12 AM
In-Zane Moderator
ZONES89RS's Avatar
Mine had the explorer axles cut off, the 10 bolt axle tubes slid in and welded. So that is one answer.
Old 03-02-2015, 12:52 PM
Rise of the Phoenix's Avatar
Yeah, what he said. If you do a 8.8/10 bolt "hybrid", you're just using the 8.8 center section, and keeping the 10 bolt axle tubes, so the backing plates and brakes work just like they would on a stock 10 bolt.
Old 03-02-2015, 04:23 PM
I thought of that but I have 31 spline axles and carrier.
Old 03-02-2015, 05:17 PM
In-Zane Moderator
ZONES89RS's Avatar
Aaaaaand.... So do I.
Old 03-02-2015, 06:11 PM
Shouldn't matter.
Old 03-02-2015, 06:21 PM
ZONE89RS.....
Are you using the small ten bolt wheel bearing. My 31 spline will not slide through the 10 bolt wheel bearing.
Sorry guys.... I am lost on this one. Thanks for your help.
Old 03-02-2015, 06:25 PM
Originally Posted by All Pontiac WS6
ZONE89RS.....
Where did you get this 8.8 from? There is a guy named Josh that makes them that are100% bolt in ready and accept the stock brakes. He welds on the 10 bolt axle tubes and he puts in custom 31 spline axles. Curious if it's one of his.
Old 03-02-2015, 06:36 PM
My 8.8 is out of a 2000 Exploder. It is a 31 spline set up. I was trying to lengthen the passenger side to the same as the driver side. Now I find out my LS1 brakes will not fit. So should I just cut the ends and replace them ones that will accept 31 spline bearings and LS1 backing plates ??
Thanks again for your time.
Old 03-02-2015, 06:51 PM
In-Zane Moderator
ZONES89RS's Avatar
You should just get some moser axles made for it. They do it all the time evidently.
Old 03-02-2015, 06:53 PM
So you are trying to make an unmodified 8.8 out of an explorer work on a f-body? Yeah, that won't work. You'd be best off to cut off the 8.8 axle tubes and weld on your 10 bolt axle tubes and then get custom lenght 31 spline axles. Then, your backing plates and brakes will work just fine. If you have FB, checkout TNT fabrication. He is going to be doing my 8.8.
Old 03-03-2015, 12:47 PM
OP, there's also several 8.8 write-ups on here from guys who have done one on their own. May want to check those out. I hope you get it all figured out. If you can, post up some pictures of the rear.
Old 03-03-2015, 06:25 PM
I have read many write-ups here but I cannot find the answer I am looking for. I would like to know if anyone makes axle ends that I can put on the 8.8 and use my LS1 rear brakes. Thanks for your help.
Old 03-03-2015, 06:29 PM
newchevyman's Avatar
TnT Fabrication on Facebook as others have mentioned. Reasonable prices and can set you up for success.
Old 03-03-2015, 06:57 PM
I wish I knew if they do or not, but I really don't know.
Old 03-04-2015, 07:07 PM
Restricted User
JoeNova's Avatar
I used a mustang 8.8.
replaced the axles with 31 spline Moser axles and used a welded explorer diff. Redrilled the rotors/axles for the 5 x 4.75 bolt pattern and used the mustang rotors/calipers. Cost me the $200 for the 8.8, $270 for axles and 25 for brackets. Was in it about $500.
Old 03-04-2015, 07:38 PM
Hey Guys,
I spoke with Josh at TNT Fabrication. Great guy to deal with. I will be sending him my 8.8 and 10 bolt tubes for him to set up. Thanks to everyone for offering suggestions, it was a great help.
David
Old 03-04-2015, 08:12 PM
Good deal man. He will hook you up. Are you going to use you stock driveshaft?
Old 03-04-2015, 08:28 PM
Haven't thought that for ahead yet .......
Old 03-04-2015, 08:39 PM
Pretty sure you can if you get the right adapter. Josh can give you the part number you'll need.
Quick Reply: 8.8 with LS1 brakes
