ROH-RT ?'s
ROH-RT ?'s
I got some newbee questions about the ROH RT's. I am looking at 18x8 front and 18x10 rear.
Are these really 18x10's or 18x10.5's / 18x8 vs 18x8.5
What do I need for these to fit, I guess a BFH and special offset?
What size tires would fit these 2 wheel sizes (preferably Nitto)?
Thanks,
Kyle
Thanks,
Kyle
WOOHOO! I just found that Nitto makes a 305x35! I was starting to get pissed cause I thought I was stuck with a Nitto 285(too small) or 315(dangerously big) Those should work perfectly. Thanks for your help.
edit: hold up, I can't find a cheap all season 265x40 tire...does anybody make one to fit a 18x8 wheel.
I do beleive the RTs come in 18x9 which would allow a 275 front. That's what I'll be doing when I order the RTs later this year.
Check out groupawheels, they are the main distributor over here in the states for ROHs. They should be able to set you right.
I have a set of 18x9 chromed Roh RTs with 275/35's Toyo Proxes T1-S.
The 17x9 and 18x9 have a 43mm offset and the 18x10 have a 49mm offset if I remember correctly.
Ask for Jeff Curran at Group A Wheels. He is very knowledgable and great to deal with. Tell him Gregg Gooters sent you.
Not yet. I should have them this Monday. The wait is killer, but two wheels were damaged beyond repair to be chromed on the way to the chromers. I don't hold anything agianst GroupA since it was beyond their control. They also handled the situation perfectly. I will post pics when I get them.
