CODE 0410 & 1133
CODE 0410 & 1133
any help anyone can give me would be appreciated... just curious what these codes are. MODS are in sig. K/N FIPK, LTs, X, !CATS, but O2 SIMS and removed in LS1EDIT. anybody got any ideas? also, the K and N filter is not overoiled....
suggestions?
suggestions?
DTC P0410 Secondary Air Injection (AIR) System
did you remove the AIR?
DTC P1153 HO2S Insufficient Switching Bank 2 Sensor 1
this code (from what ive read) sometimes shows up on cars with aftermarket headers/exhaust because the aftermarket exhaust does not let the o2 sensor heat up properly. someone correct me if im wrong, im just restating what i remember reading on ther threads.
I used to get the P0410 after I installed my K&N, but it was because they didn't send me the little breather filter, so it was sucking un-restricted air in. That was an early-on issue that all the vendors have corrected for now.
I have the breather that goes along with the K & N. My Rear O2s are removed via LS1edit. I just need to know if this is something I should worry about....
I also noticed that I back fired after releasing from WOT last nite
