June Nitrous Specials From Nitro Daves!!
THIS SPECIAL WILL BE GOOD UNTILL THE END OF JUNE.
KIT#1
1.OUR HALO DRY KIT,comes with our halo spray bar,10lb bottle(black or White) fuel pressure safety switch,nitrous pressure gauge,NHRA blow off valve,blow down tube.Regular hard ware such as microswitch, lines, wiring, hardware ETC.
2.860 Performance heated bottle brackets.(best described as a hot plate with bottle brackets)
3.NX purge kit
4.MSD window switch with 3,000 and 6,000 pills
5.8-NGK TR6 spark plugs
6.860 Hex To Wing Nut
All this for 835.00 shiped in the US
KIT#2
1.NX Maff Kit-20920-10
Comes with 10lb bottle,Ice man lifetime warranty solenoids,TPS switch,Mass Air ends,bottle brackets,lines,hardware,etc
2.GENX-2 upgrade-Comes with automatic bottle heater,purge,fuel pressure safety switch,NHRA blow off valve,blow down tube,nitrous pressure gauge,wiring and fittings.
3.MSD window switch with 3000 and 6000 pills
4.8-NGK TR6 spark plugs
5.860 Hex To Wing Nut.
All this for 1310.00 Shiped in the US.
KIT#3
PIMP YOUR KIT
1.NX 2 1/16 piller mounted electric nitrous pressure gauge.Comes with harness and has white face.
2.860 V twin purge
3.860 Hex To Wing Nut
275.00 Shipped in the US.
Call in your order at 1-866-648-7637
KIT#1
3.NX purge kit
KIT#2
KIT#3
PIMP YOUR KIT
2.860 V twin purge
I have the NX MAF kit, just wondering if it has always come with the Ice man solenoids, or if they are something new.
Ill be buying all my accesories from you in the future
Mark
Mark
