TCI 3500 problems help!
Old 06-06-2004, 02:50 AM
Blue2002SS's Avatar
Default TCI 3500 problems help!
I have had the converter in for about a week now and about half the time it does not want to lock up. I can go 60+ MPH and it still will not lock up. The rest of the time it will lock up just fine.
Next when it does lock up I hear a loud noise like running over the rumble strips on the expressway. The only way to avoid this is to speed up quicker and then let off the gas so there is no load on it when locking up. Or if I am driving around under 60 MPH with it locked and just press the gas pedal a little to hard it will do this also. what is wrong???
Old 06-06-2004, 10:30 AM
Colonel's Avatar
"Next when it does lock up I hear a loud noise like running over the rumble strips on the expressway."
This part concerns me. That sounds like either a bad lockup clutch (converter's fault) or not enough pressure being applied to it (tranny's fault.)
I'd give Kevin Winstead at TCI a call.
Old 06-06-2004, 10:39 AM
PREDATOR-Z's Avatar
I do not think its a bad converter. I've had the same symptoms with the stock tranny. Cured it with raised shift speed points (3>4) and tranny pressure.
This was only noticeable with normal load and not under wot.
Old 06-07-2004, 06:42 AM
Kevin Winstead's Avatar
Hi Blue,
You can give me a call at (662)224-9355. It's your TCC that is slipping. There could be a couple of different reasons why.
Kevin
Old 06-07-2004, 11:40 AM
Blue2002SS's Avatar
Kevin I will give you a call later on today. thank you
Old 06-08-2004, 04:35 PM
PREDATOR-Z's Avatar
Originally Posted by Kevin Winstead
Hi Blue,
Kevin
Pardon my ignorance but what is TCC??
And why not post the reasons?
Old 06-09-2004, 04:07 AM
Blue2002SS's Avatar
I think TCC means Tourqe Converter Clutch, but I am not sure on that.
I talked to Kevin and he said there was not enough pressure pressing on the clutch or somthing like that and it was either the rubber ring around the shaft on the transmission or it was the converter itself causing the problems mentioned above.
So after work tonight I tore into it again and got the converter out. After inspecting the O-ring it looks fine. guess I need a new converter
I hope all that made sense its 5 am and I need sleep
