How Much Hp Can I Get From A 382
Old 06-06-2004, 11:41 AM
hydfixer's Avatar
Default How Much Hp Can I Get From A 382
How much do you think the avarge hp is from a 382 with G5X2 cam and good set of heads?
Old 06-06-2004, 11:49 AM
Orange Peel's Avatar
Uh oh, not happy from yesterday dude?? What did you put down?
Old 06-06-2004, 12:31 PM
Scalpel's Avatar
Well that cam was designed for stock head 346 LS1s. You don't have an ideal cam for your engine combo.
What's a "good" set of heads? What size valves? What's your static compression ratio? What are the flow #s?
There's really no way to guess an average. However, most people use 1.4hp/CID, so:
1.4hp/CID * 382 CID = 534 HP (crank) * 15% drivetrain loss = ~450 RWHP
Old 06-06-2004, 01:17 PM
hydfixer's Avatar
Thumbs down
It fell on its face 410 should be 510 with all the **** done to it, going to build a 382 and spray 300 or what ever I need to spray to get 800rwhp. You should be happy with your hp, very nice and only go up from there. Well mabey not, I went from 445 to 410 with heads and 90mm LSX + 90mm TB. Go figer.
Old 06-06-2004, 01:20 PM
hydfixer's Avatar
What would recomend for a cam then?
Old 06-06-2004, 01:30 PM
Scalpel's Avatar
I'm not a cam designeer but you definately need to get in touch with any of the tuners at the right, Futral, MTI, LG, etc to get a custom spec cam to your goals. An off the shelf grind will not give you the #s you want.
Was the car dyno tuned? If so, was there any KR, etc?
Too little info to really help you out very much.
Old 06-06-2004, 01:43 PM
hydfixer's Avatar
Yes it was dyno tuned, no kr at all, I had the heads done by a local porter and he said he ls1 experance, he messed with the combustion chamber to much and got ride of the point between the valves. Now I find out that if touch the chamber you lose the swerial and hp.
Old 06-06-2004, 01:53 PM
Scalpel's Avatar
Can you send me the dyno graph so I can post it? lprocter@alltel.net
Did you get flow #s on the heads? Were the heads milled any? Is the valvetrain setup correctly?
Old 06-06-2004, 02:04 PM
hydfixer's Avatar
the heads were milled .010, I had Xtrem motor sports put the heads on so it should be right. I used h/s rockers. The heads have 2.08/1.06 and @ 600 lift they flowed 335 and 230. On the dyno the curve started to drop 6300.
Old 06-06-2004, 02:27 PM
CHRISPY's Avatar
Did you flow the heads independantly? What tranny?
You should be in the 450-470 range with that cam if the heads really flow in that range.
Old 06-06-2004, 02:38 PM
Scalpel's Avatar
If it's falling off big time, it could be lifter issues, valve float, etc. The dyno graph could help us out.
Old 06-06-2004, 05:02 PM
hydfixer's Avatar
I will scan the graph and post it on monday.
Old 06-30-2004, 08:37 AM
VSGLS1's Avatar
Any updates, you should be able to hit 450 with decent heads and a moderate cam.
Old 06-30-2004, 09:33 AM
gator's 99TA's Avatar
way way too many variables. you need a full breakdown for us to even get a picture of what is going on. those flow numbers sound outragous, not saying it isnt so, but if it wer true, then a big cam could easily push that motor to high 490 rwhp if it is a manual tranny.
Old 06-30-2004, 09:45 AM
SAM98WS6's Avatar
I have 480rwhp..10.5:1..M6 all heavy stuff and no dyno tricks...your heads should get you 500rwhp..since mine only flow ~310cfm@.600
242/250 .595/.595 109 ..get the G5X3 or one like mine...still not enough..
Old 06-30-2004, 09:47 AM
kumar75150's Avatar
ya I have almost an exact same setup as Sam
480something hp with a 244/250 cam and heads that flow 309 at .600
Old 06-30-2004, 11:52 AM
SAM98WS6's Avatar
Go with 1 3/4 headers stepped to 1 7/8"..wish I would have for a little more power....
Just make sure you put a big cam in..no reason not to.
Old 06-30-2004, 08:18 PM
8 Sec Tuner
Mike TexaSS's Avatar
I made 455 RWHP and 438 RWTQ with a Lunati Stroker kit and a decent set of ls1 heads and a X1 cam. It drives and idles like a stock car.
With a set of the AFR's and a bigger cam plus a 90mm Intake i could make 500 RWHP easy.
EASY!
Old 06-30-2004, 08:27 PM
Ben R's Avatar
Get rid of that weaksauce cam first!
Old 06-30-2004, 08:48 PM
Shorty Director
VINCE's Avatar
Dont always go by head flow #'s. Trust me on this one..
