P to V question
Old 06-07-2004, 09:11 AM
Moderator
JNorris's Avatar
Default P to V question
Which cam will have most P to V clearance on the intake side?
Will all of these cams have enough P to V clearance to be run with 5.3 heads milled .015 with 2.02 intake valves?
230/224 .573/.563 ICL=111 LSA=111
230/232 .591/.581 ICL=108 LSA=112
230/232 .591/.591 ICL=110 LSA=114
230/232 .591/.591 ICL=110 LSA=112
Thanks
John
Old 06-07-2004, 09:26 AM
evilz06's Avatar
I have a calculator that wll calculare P/V clearanse from any cam, valve relieve, timing events, etc. Just let me know if you want me to figure it out.
Old 06-07-2004, 11:48 AM
Moderator
JNorris's Avatar
PM sent.
Thanks
Old 06-07-2004, 12:36 PM
1fastWS6's Avatar
numbered worst to best, #2 will be the same but the 114 lsa will have better clearance on the exhaust side.
1) 230/232 .591/.581 ICL=108 LSA=112
2) 230/232 .591/.591 ICL=110 LSA=112
2) 230/232 .591/.591 ICL=110 LSA=114
3) 230/224 .573/.563 ICL=111 LSA=111
Don't quote me on this, but I'd think #2 and #3 should fit fine, but #1 might be on the tight side.
Old 06-07-2004, 08:25 PM
Moderator
JNorris's Avatar
Thanks for the response. So the lower the ICL the less P to V clearance you have?
John
Old 06-08-2004, 12:17 PM
1fastWS6's Avatar
John
Yes, with all else being equal, it means that the valve starts opening earlier when the piston is closer to TDC.
