Should output shaft have play?
Old 06-07-2004, 07:47 PM
theblur98ss's Avatar
Default Should output shaft have play?
I just took my driveshaft out to pull my center section and I noticed the output shaft of my TH400 has a good bit of side to side and up/down play. Is this normal or is there a bearing wore out? The tranny only has about 1000 miles on it.
Old 06-08-2004, 08:56 PM
Anyone out there?
Old 06-09-2004, 04:34 PM
aram's Avatar
My output shaft had a lot of play in it on my TH400 when I put it in.. I was worried since I bought it used. I've driven maybe 700 miles on it and so far it seems to be working fine.
Old 06-11-2004, 01:40 PM
robertbartsch's Avatar
Neh; it is designed that way...it is supposed to have some play...
