A/F goes to 11:1 @ 5000 '04 Corvette
Anyone try to tune an '04 Corvette. The thing goes fat at 5000 no matter how much I decrease the PE multiplier vs. rpm using LS1 edit. There has to be a way to lean out the mixture using some other table. I've been told GM does that to keep the engine safe, but it's sure hurting the power...
04 vette 02's go fat at 5000
Does the COT cause the A/F to go fat at about 5000 rpm? If so, will raising the COT temps fix it? Can you just turn the test off if you have no cats?
Excuse my ignorance, but what does COT stand for? I think this may be happening with my Monaro. The current model runs much richer than before under WOT, and it may be fuel dumping and cutting power.
Where do I find it in LS1 Edit?
