427 Ci
With a new job coming up i will have an extra 1500 a month to blow on the TA. Where do i get a block at first? Need to do it in steps because real bad at saving money. Figured id buy a block first then a package for the internals (stroker kit). Was going to go with a 383, but figured the 427 will not be that much more money or wil it?
The 427 will be about $2500 more than the stroker the only difference will be the block and some extra porting on the heads. We are seting up a couple of 427 Darton sleeve blocks at the moment. Let me know we can get you some pricing.
Nate
Nate
So, comparing a stock block/crank (forged) motor to a stroker to a stroked/bored setup (like the 427), the price breakdown goes like this, correct??
Stock block/crank- forged rods, forged pistons, balancing
Stroker- stroker crank, forged rods, forged pistons (I assume that the cost would be roughly the same as forged pistons in the stock block/crank motor), balancing
Stroked/poked- sleeved block, stroker crank, forged rods, forged pistons (again, I assume that the cost would be roughly the same (within a couple of hundred dollars) as the pistons for either of the other two applications), balancing.
Or am I missing something?? Let's say that you could find a stroker crank for $1k, and a sleeved block for $2500... since we're assuming that rod/piston cost for each motor is the same (also assuming that balancing costs are in the same ballpark), does that mean that a 427 (short block) could be assembled for ~$3500 more than a forged 346??
Obviously, heads to match the 427 are going to cost a bit more, but other than that... or is there a whole mess of other machine work that has to go into the 427??
https://ls1tech.com/forums/generation-iii-internal-engine/177740-jpr-427-coming-apart-literally.html
Originally Posted by Bear
You better make sure your #8 piston clears the reluctor wheel or you will have one big mess on your hands, KINDA LIKE ME.
https://ls1tech.com/forums/showthread.php?t=177740
IMO and based on experience, who ever you select to build your engine, have them do the install and tune (turnkey). Eliminate finger pointing. Also go with a shop that has been in business for several years...do not do dry sleeves, consider the C5-R block.
or darton wet sleaves...... dry sleeves... yuck..
