Question about hurst skip shift?
Old 06-08-2004, 11:49 PM
2_wacko's Avatar
Default Question about hurst skip shift?
I recently bought the hurst skipt shift and was wondering if the skip shift light is still suposed to come on or not. Mine still come's on is this right?
Old 06-09-2004, 12:10 AM
99'Formula's Avatar
mine doesnt but I have LS-1 Edit but I think if your just buy a skip shift emliminator it still stays on...I think
Old 06-09-2004, 05:40 AM
2_wacko's Avatar
ttt--------
Old 06-09-2004, 06:16 AM
STF Veteran
TA TED's Avatar
Skip shift eliminators will not interrupt the Shift Light Circuit. Either use LS1 edit, or disconnect the light ground discrete at the PCM. Cut the wire and cap the ends. The PCM will store a fault for the lamp control circuit being defective, however it will not trigger a SES light.
Old 06-09-2004, 06:58 AM
DJ_951's Avatar
Yes the skip shift light will come on still. Just smile knowing you don't have to shift to 4th gear.
Old 06-09-2004, 07:12 AM
It's not mine! woo hoo!
demonspeed's Avatar
FYI - the skip shift has nothing to do with a Hurst shifter.
Old 06-09-2004, 07:19 AM
2_wacko's Avatar
I liked the skip shift as soon as put the thing on I just did not know if the light was suposed to come on or not.. Thank's for the info.
Old 06-09-2004, 12:20 PM
Strahley's Avatar
Hurst makes a !CAGS? Didn't know that
Or are you saying you bought a Hurst Shifter? If you bought just a shifter, then no that will not eliminate the skip shift. That's something different
But yes, when you disable CAGS, the "shift" light will still come on. It won't go away until after you have engaged in another gear (normally 2nd)
Old 06-09-2004, 01:54 PM
2_wacko's Avatar
Yes Hurst make's a skip shift some of the sponser's sell it.
Old 06-09-2004, 05:11 PM
demonspeed's Avatar
The way you made it sound was it had something to do with the Hurst shifter itself. I think that's why some of us were confused
