Best stroker kit on the market?
Old 06-11-2004, 10:46 PM
koniu77's Avatar
Default Best stroker kit on the market?
can someone tell which stroker kit is best for my ls1, i need top of the line everything. also, does anyone make titanium connecting rods for our engines?
Old 06-11-2004, 10:49 PM
11 Bravo's Avatar
Lunati makes the best kit. Don't know about ti rods lol
Old 06-11-2004, 10:50 PM
jrp
SN95 Director
jrp's Avatar
uh, a little more info would help. like what size stroker kit your looking for and the application its going to be used for. lunati's kits are usually top notch.
Old 06-11-2004, 10:54 PM
koniu77's Avatar
was thinking about 383. no juice, and no boost
Old 06-11-2004, 10:58 PM
jrp
SN95 Director
jrp's Avatar
with those low requirements i'd look into the eagle kit and save some money :shrug:
Old 06-11-2004, 11:02 PM
koniu77's Avatar
im not looking to save money (have a sponsor to pay for all of this) just looking to have the best stuff available.
Old 06-11-2004, 11:05 PM
jrp
SN95 Director
jrp's Avatar
sweet, well in that case get the lunati kit
Old 06-11-2004, 11:09 PM
Quickin's Avatar
Custom built titanium alloy parts, then spray a 500 shot $40,000 should do it.
Old 06-12-2004, 07:51 PM
JZ'sTA's Avatar
Damn Quicken that is a sweet way of being really fast in a daily driver.
434ci and a 4L60E with 3200 converter.
Nice.
BTW if you have a sponsor why stay at 383 when you can go bigger?
Also give it a couple of months before you order heads and see what the sponsors on this board can do with the AFR heads.
Old 06-12-2004, 08:11 PM
Quickin's Avatar
Nice.
Thanks. But don't forget those other 2 cubic inches, its a 436ci
I'm gonna add a FAST 90mm intake and 90mm TB with a 300 shot DP soon, now that'll make for a serious street monster
Old 06-12-2004, 08:31 PM
Colonel's Avatar
Titanium connecting rods......let me know where you find those and how much they co$$$t!
Old 06-12-2004, 08:46 PM
koniu77's Avatar
my friend told me that acura nsx has titanium connecting rods from factory
Old 06-12-2004, 08:52 PM
Cheatin' Chad's Avatar
Your friend is correct, they do come stock with Ti connecting rods in the V-6 engine.
However,That stock $90k NSX will also get the crap kicked out of it by a stock,$52k, Corvette Z06 that uses steel connecting rods and pushrods to actuate it's valves. You pick the track, a stock Z06 Corvette will dominate a stock NSX.
Don't fall for the hype. Just because it's Ti does not mean it is "the best" the best is different depending on what you are trying to do.
If you're building the engine yourself or the guy that is building it for you doesn't know how to get Ti rods you/he probably shouldn't be messing with them. Ti is extremely notch sensitive. That means even a small scratch will act as a stress raiser and can lead to failure.
Ti rods (and many other things) must be handled and installed by a consumate professional in order to get the best from them.
