Will FM-5's meant for a C5 fit on a F-body?
Originally Posted by VINCE
Do you by any chance know the offset? Will I need spacers to push them out a little?
Originally Posted by Xsta Z 28
Sorry I do not. As for the spacers, I cannot really say. In general, they will fit, since Corvette wheels typically fit a F-Car, but they are not going to have the same stance as FIKSEs made for an F-Car.
Basically you are saying the lip is not going to be as deep?
If the offset is 56mm like most C5's are I can use a small spacer to push it out to get a better stance correct?
Correct.
The offset more than likely is a little less than 56 mm since FIKSE is very aggressive with their offsets, but yes one could use spacers to get a better "stance" I highly recommend better studs, if you go the spacer route, and invest in good quality hub and wheel centric spacers for outfits such as H&R Springs.
Ok, I found an old post with this link. http://www.hrsprings.com/site/index.html
$150 for spacers. 25mm seems a little huge?
Originally Posted by Mark IXZD 150
This is Andy (Xsta Z 28) No 25 mm is big. Nearly 1". If I recall correctly they had 8 mm and 15 mm versions. FYI 1" = 25.4 mm.
