why did the "change oil" light just come on?
Old 06-13-2004, 05:51 PM
02blackws679ta's Avatar
Default why did the "change oil" light just come on?
i just changed my oil not even 100 miles ago probably....just now when driving home the change oil light came on...in my truck the oil light is just a timed thing that goes by the odometer i guess, is it the same with our cars? was my light just not reset or something?
TIA
Old 06-13-2004, 06:01 PM
2000Blackout's Avatar
FYI you have to reset it,everytime you change the oil,its a pita to remember sometimes.
Old 06-13-2004, 06:11 PM
how do you reset these? and why did it just now come on, even though i was about 1k miles over 3k before i changed it? what are they set to go off on?
Old 06-13-2004, 06:36 PM
01_SuperSlow's Avatar
Turn the ignition on, engine off, press and hold the oil/trip button by the odometer for about 12 seconds and it will reset itself. According to the GM manual, the change engine oil light is not based on mileage, but on engine rpm's and engine operating temperature .
Old 06-13-2004, 06:37 PM
LS1TECH Sponsor
foff667's Avatar
when you reset it it goes back to 100% efficiency basically...now depending on your driving habits ie rpm fluxuation during a givin timeframe, startups blah blah blah it calculates the efficiency of the oil...if you start your car twice a day 5 days a week and then drive at 2000rpms for an hour and lets say rack up 70miles each way a day thats gonna be alot less wear then if someone started the car 16 times a day and drove 8 miles of city traffic between startups...basically same mileage but different rpm ranges and such. Some might make it 6000 miles before it pops up to change it some 1000 if you dragrace with the car every other day so its all about your habits not the mileage generally.
Old 06-13-2004, 06:56 PM
thanks for the information, very useful! i wasnt quite sure how ours were gauged, but i know now
Old 06-13-2004, 08:01 PM
KimberWS6's Avatar
All I got to ask is are you running a Fram oil filter?
If you are that the problem they resrict oil at start up thus triggering the light, had the problem with my Z71 all the time till I switched filter brands.
Old 06-13-2004, 08:02 PM
i doubt it, i didnt change my oil this time but im sure they didnt use a fram
Old 06-14-2004, 12:02 AM
LS1Maniac's Avatar
Nooooo I love Fram filters. They have that uber nice grippy thing so it's easy to put on and take off. Don't tell me there's anything wrong with them .
Old 06-14-2004, 08:49 AM
Scalpel's Avatar
Fram's are the biggest POS.
I gained over 7 PSI of oil pressure by switching out one of their X2 Fram's (something like that).
K&N are the way to go.
Old 06-14-2004, 10:11 AM
LS1TECH Sponsor
badpewter-z's Avatar
back in the day when i thought fram was good never understood why oil got dirty quick , all i run is ac-delco stock filters and never had an issue and stays clean ,
Old 06-14-2004, 10:22 AM
JS
JS's Avatar
Fram HP series is very good but they dont make them for our cars.
Old 06-14-2004, 10:41 AM
cantdrv65's Avatar
Red face
You'll gain even more oil pressure if the oil filter had no element at all...
Old 06-14-2004, 07:24 PM
Grimes's Avatar
If you want to reset the light without resetting the odometer, you can turn the ignition key to "ON" without starting the engine, then press the accelerator to WOT two or three times in quick succession.
Old 07-22-2004, 08:44 PM
ccsanders01's Avatar
Default Oil Light Oil Filters
I HAD WORKED FOR A PARTS STORE FOR 5 YEARS WE ALWAYS HAD REPS IN THERE FROM DIFF. MANUFACTURERS,WE HAD CUT OPEN A FRAM FILTER AND FOUND ALOT OF CARDBORD, VERY CHEAP BYPASS SPRING, AND VALVE. I DO NOT RECCOMMEND A FRAM FILTER, TRY A WIX BRAND FILTER, NAPA , CAR QUEST THANK YOU CHAD SANDERS
