Removing !AIR Question
Old 06-14-2004, 02:41 PM
Broken041's Avatar
Default Removing !AIR Question
Today was clean up the engine bay day. EGR, gone. AIR, gone. I pulled the AIR tubes, made my block off plates and then began to remove the hose all of the way to the pump. In the rear of the motor, both hoses went into a diaphram type deal. It had both hoses entering it, as well as a third smaller vacuum line. Both of the big hoses are gone, but the small vac hose still remains. So this is the question. Can I just block that hose off without any negative results?
Old 06-14-2004, 03:39 PM
yellowbird's Avatar
yes, just plug that little hose of or your gonna have a vacum leak. good luck.!
Old 06-14-2004, 09:15 PM
2001 White Ws6's Avatar
I did this recently on my 01 Ws6. I just plugged that small tube on one of the coil pack bolts or one of the many back there.
Old 06-14-2004, 10:23 PM
Danny2tek's Avatar
The 98-99's don't have this extra hose correct? I could have sworn I read that somewere.
Old 06-14-2004, 11:01 PM
jrp
SN95 Director
jrp's Avatar
you are correct. that extra hose only applies to the 00-02 cars.
Old 06-15-2004, 07:19 AM
Broken041's Avatar
Even better, thanks! I had already stuck a small bolt into the hose, but wanted to make sure that was the correct procedure. On a side note, the engine bay does look a little better to work in now. Seems odd, but it makes the engine look even further back under the cowl now.
