Problems with P0410
Old 06-15-2004, 01:19 PM
RedWS6 00's Avatar
Default Problems with P0410
Hi, Hope someone can help.
A trouble code has popped up, P0410, its to do with the emmisions, the secondardy air pump to be exact. I have used EFILiveV6 and manually turned on the air pump so I know the pump works.
The code came up when gradually decellerating down hill at around 30mph, all data at the time captured looks pretty normal, saw the short term fuel trim was at -43% no sure if that is normal as never monitored that one before.
Hope someone can give advise on this.
Thanks
Dan.
