Whats going on here?
Old 06-16-2004, 01:36 PM
ls1perfcar?'s Avatar
Default Whats going on here?
I put a new motor in my car started it no oil pressure..... So i took it apart and put a new oil pump and o ring on there and started it with the water pump and radiator off and i had 30 psi of pressure at idle..... then i put the radiator and water pump on and started it .. nothing. Sometimes when u start it at idle it will have 10psi but other times u will start it and nothin and the ses light is on. What could be the problem. I think this car is justa pos.
Old 06-16-2004, 02:07 PM
robertbartsch's Avatar
...did you replace the plastic cap on the back of the engine block between the tranny and block - it seals the oil passages and does not come installed with fresh engines...
It could also be the o-ring around the oil pump pick-up tube.. ... a classic cause of little oil pressure... did you smash the oil sending unit when installing the motor?
Old 06-17-2004, 12:07 AM
That plug under the rear cover? No the oil pressure sensor is fine and we put a manual gauge on it and it had no pressure. So its either the o ring on the pump or that plug correct? Because from what i read if the plug isnt installed then the oil pressure sensor wont tell how much oil pressure the motor really has. But ill check it out tommrow.
Old 06-17-2004, 02:18 AM
Ben R's Avatar
If none of that stuff seems to work, try changing the oil filter. I know it sounds basic but I've seen BRAND NEW Fram filters get clogged and prevent the flow of oil.
Old 06-17-2004, 12:10 PM
Well i found out the the plug on the back of the motor isnt there. So im gonna put one in there and maybe it will solve all my problems. I had a fram filter on there but some1 told me that it suxs so i put a acdelco on there so im hopin the problem was the plug but thanks guys.
Old 06-17-2004, 02:34 PM
strokedls1's Avatar
That should solve your problem. Good luck and don't give up on it.
Old 06-19-2004, 03:08 PM
welp i got oil pressure now and my transmission went out so i gave up and traded it in for a cobra and ive never been happier
Old 06-19-2004, 03:38 PM
Loudmouth LS1's Avatar
Your kidding, right?!
Old 06-19-2004, 04:15 PM
PHANTA-Z's Avatar
Thats the funniest post ive ever seen. R U serious? Good luck with the new whip if so.
