What Rpm and PSI for Nittos
Re: What Rpm and PSI for Nittos
Select the rpm you want to launch at, then try dropping your psi, until you hook up on the launch.
remember that nittos need to be heated up very well!
the trick to nittos is to smoke them in the edge of the water box for 4-5 seconds, then burn them almost up to the line.. you gotta keep them hot and water off them..
some guys burnout then stop, and creep up to the tree.. then the tires are sorta cold by the time they get there <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
i run 19-20psi
i run 19-20psi
Do a REALLY good burnout! I keep mine at 18 lbs, and launch at 3500 RPM and it hooks awesome! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
