Update on my Buildup with pics!
Things are coming along!!
Final assembly happening today!!
Here are the specs:
Engine Specs:
Agostino Racing 385 cubic inch Aluminum Motor
Eagle 4 inch stroke crank
Eagle 6.125 forged rods
Diamond 3.907 forged pistons with valve reliefs
ARE Stage III CNC LS6 Cylinder Heads with hand porting/finishing 11.5:1 Compression
2.055/1.57 valves, double springs, hardened pushrods, titanium retainers
FM Bearings, Diamond ring kit
238/242 110LSA XE-R cam
ASP crank and Alt U/D pulleys
Edelbrock 1 3/4 to 1 7/8th Longtube headers with 3.5 inch merge collectors and dual cutouts
LS6 Intake with ported throttle body and stock MAF (descreened)
ARE LS6 CNC Stage III Cylinder Heads with Hand Finishing/Porting Numbers are in the 327cfm range at .600 lift
Diamond Pistons and Eagle Rods
Comp XER Camshaft
Eagle Crank
Diamond Piston
Bore
and here are the new headers
Getting excited now!
Thanks to ARE for all their hard work on this!!
Chris
Here are the specs:
Engine Specs:
Comp XER Camshaft
Eagle Crank
Diamond Piston
Bore
Chris
Thanks guys!!
I am really excited to get everything together as you can imagine.
Brian from ARE is doing the whole engine buildup and is very meticulous and sharp. I am looking forward to see the final combo together
Goal is 10.60's-10.80s@127-129mph on slicks at 3400-3500 pounds
Low 11's@126mph plus on a DOT legal street tire
I'd love to hit 3200 pounds raceweight but it is going to take $$$.
Chris
Chris
Originally Posted by Ragtop 99
Bring it to Cecil and let me drive it. It will save weight and not cost big $$$
BTW I found out they finished assembling the short last night
things are rolling now
Originally Posted by Chris ARE 360
What do you mean budget header choice? That header will outperform most headers 3x the cost.
thanks guys, I think the longblock is assembled now. Just waiting on some pics from a friend that was at the shop the other night.
I'll post them up when I get them
Car update!!!
Motor is in the car (waiting on pushrods)
BMR Extreme Torque arm/subs are in
Fuel pump (Racetronix 340 with harness) is in
headers are on
Exhaust (Off road Ypipe with dual cutouts) gets made tomorrow and then it is going on the dyno
I'll keep you posted I should be picking up the car tomorrow night. If all goes well I am going to break it in all week and hit the track on Saturday or Sunday for a few shakedown passes
Can't wait to hear the dyno numbers!!
Chris
headers are on
Chris
