Fueling & Injection - Ceramic coated fuel rail, ruined o-rings in it, fixable?
C4VetteLS1
06-17-2004, 11:25 AM
Ack, i had my dual inlet 97-98 corvette fuel rail (the one with the return line) ceramic coated. I put fuel pressure to it on the car and instantly blew fuel everywhere out of the regulator on the crossover tube. I popped the snap ring off and pulled the regulator piece and looks like it has two o-rings that used to be there before they were melted.
Is the regulator part replacable or should i just get another rail.
jimmyblue
06-17-2004, 01:27 PM
If it trashed the O-rings, it may also have cooked
the diaphragm inside the regulator body, if there's
that kind of soft parts inside the "pod"; I expect
you should just buy a new regulator and try to
find a way to get the new guts into the pretty
reg shell?
C4VetteLS1
06-17-2004, 01:29 PM
Just called dealer, they have the regulator for $60. I ordered one. You think that replaces all the nessesary parts that melted?
John_D.
06-18-2004, 12:19 PM
You might ought to replace the scrader valve too, just to be safe.
C4VetteLS1
06-18-2004, 01:55 PM
ohhh never thought of the schrader valve...ill change it out as well
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
