how to install valve seals?
Old 06-18-2004, 04:58 PM
mattz06's Avatar
Default how to install valve seals?
installing new patriot springs and valve seals. just pry the old ones up? slide the new ones down? tap themdown? how do you know they are fully seated?
thanks!
Old 06-18-2004, 11:22 PM
busavette's Avatar
just put mine on ,just tap em on & they wont go much further theyll bottom out,when you do the next few theyll all show the same amount on the guides.
Old 06-19-2004, 11:59 PM
TT-TECH Veteran
Inspector12's Avatar
I use a socket that is just a little bigger than the seals with an extention and usually able to push on by had but when I get to the back ones I might use a little tap with a hammer ETC... Just look and see if they all look fairly equal.
Old 06-20-2004, 02:19 AM
35th SS's Avatar
just did mine today vlv. seals and swap to dual springs on the car.what a pain in the *** to do on #8 springs.getting ready for the trex cam.
Old 06-20-2004, 07:28 PM
mattz06's Avatar
thanks guys!
