New Bogart Welded RTs and M&H Musclecar Drags pictures
Hopefully the pics show up...
I have 16" road race RTs on order for the front
The M&Hs measure 26.5" tall (advertised as 26.2"), 275-50-15s.
My stock 16x8 rim & 245-50-16 Nitto was 41.6lbs.
The 15x9.75 bogart : 11.6lbs ... w/ M&H 34 & 35 lbs ...
They actually varied by 1 lb- I assume it was the tire, I only
weighed one wheel before mounting.
I tried the M&H based on a couple people here's experience.
It's a bias-ply tire, but seems a step between a street slick
and a drag radial... we'll see. I wanted to get a little more
streetability than an et street.
I will post full car pics when my front Bogarts arrive shortly.
As you might imagine, MUCH better hook than the nittos. On the street, with the front sway bar bolted down, and obviously tires not heated up, I detect some slight spin- but I can still give it full throttle and it will make it to the 1-2 shift with what appears to be just slight spin. I figure a little heating up the tires and/or sway bar end link disconnection and I should have full on hook. Got to be only a 5000mi tire max though. But 1st gear was unuseable with the Nittos. Now I can enjoy it a legal speeds.
I run 23 PSI on the street and 21 at the track and the car dead hooks on every pass..Very predictable tires..I just recently was able to get a set of the new ET Street radials in the 275/50/15 size and will hopefully get back to the track once our Louisiana heat wave gets a little better..Here's a screen grab from a couple of Saturdays ago in +3100 DA...
Originally Posted by nuckifuts
where did you buy your bogarts from? thanks, rich.
Originally Posted by So Slow
The M&H Muscle car street tire is a great Street /Strip tire..I'm on my second set this year and with Interco just a hour from my house its easy to run to the manufactor and pick up a set..The tires will hook on just about anything and will live longer then a ET Street..
Originally Posted by InvisibleSun
Please post up when you get your results. I am dying to know which one of these two tires hooks up better!
No problem..I mounted them this morning and hopefully will run the car in the next couple of weekends..
Hey So Slow - have you had a chance to drive on the ET Street DR on the street yet? Just wondering how the street manners are compared to the M&H Muscle Car tire...?
