15x3.5 Weld Skinnies - Need Longer Studs On Front?
1st, I understand that if you run a 5/16th spacer, you don't need to grind the caliper, correct??
2nd, with the spacer, do the stock wheel studs work or are they too short?? Have you guys had to replace them??
Thanks!
Mark
Thanks!
Mark
Re: 15x3.5 Weld Skinnies - Need Longer Studs On Front?
As an FYI...because the are a two-piece wheel, NHRA rules require longer studs. Whether or not your track will check for that is another thing...but to be legal, you need the longer studs.
Bob
Bob
That's strange that some cars can get away with a spacer and some still need grinding!
Longer studs with open end lugs, right?
Thanks guys!
Mark
Thanks guys!
Mark
How are you guys changing the front wheel studs without the special "KentMoore" GM tool?? I don't know how comfortable I am with just screwing a lug on and banging them out!!
Any ideas!
Mark
Any ideas!
Mark
