Changing Out To Longer Front Wheel Studs
How are you guys changing the front wheel studs without the special "KentMoore" GM tool?? I don't know how comfortable I am with just screwing a lug on and banging them out the old fashioned way!!
Any ideas!
Mark
Any ideas!
Mark
Moderator
Re: Changing Out To Longer Front Wheel Studs
I get out the BIG hammer with 2 big hits <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> the old one falls out. I clean out the stud hole, slip in the new stud, put on a few washers then the lug nut and tighten it till it seats completely.
John
John
Moderator
See the post below for the GM longer wheel stud part number.
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=5;t=000932
John
John
How long are the studs you recommend? With a spacer, do they meet the "width of the stud into the nut portion" to be NHRA legal??
Mark
Mark
Wheels up Director
Like above I got a big hammer and a couple whacks later the old ones are on the floor. Then I added a little antiseize to the knurl and just turned the stock lug nut backwards and 45 seconds later the new stud is seated perfectly <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
LAter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
yep. thats how i do it. big hammer, spare lug nuts, 600ft-lb impact wrench <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Wheels up Director
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Reckless:
<strong>Lingenfelter also sells the longer studs on their web site.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">For about twice as much as your local dealer. I made that mistake. These are the SAME studs from your dealer or Lingerfelter
Wheels up Director
Here's a pic of the front hub with a stock stud next to it. Let's see if this works
Front hub
<small>[ April 21, 2002, 02:44 PM: Message edited by: Bob2of3 ]</small>
Front hub
Wheels up Director
I didn't take the hub off the car to replace the studs thats for something else <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" /> I had no problems with everything on the car
I just jacked up the car, took the tire off and started hitting <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> the studs out. Yes leave the hub on it ie REALLY easy to do.
I have to update... I ordered mine from the dealer. A few whacks on the old ones and using a lug nut and a cheater bar had the new ones in in about an hour.
Another project done with the help of www.LS1tech.com
How long are these studs?
I measured the stock ones after I got them out. Total length = 2" The ARP ones that I got (P#100-7708) are 2 3/4" long.
Much better but with a 5/16'th spacer and Welds they are about 1/2" away from being legal. If the dealer or LPE ones are longer than 2 3/4" (total stud length) I need to know!!
Thanks!
Mark
Thanks!
Mark
Confirmed with ARP that these are the longest 12mm's they have.
Looks like the only options are the dealer (LPE) studs if longer or 7/16. Has anyone replaced the 12mm with 7/16 in the front hub - do they work?? If so, length part numbers??
Thanks guys!
Mark
Thanks guys!
Mark
I'm waiting for the longer GM studs to come in as I write this. I could swear I saw something saying that these are 3 1/2" long.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Bob2of3:
<strong>They are 68mm long
LAter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So that is 2.67717 right? Which means the ARP ones are just a bit longer, so I guess that makes up my mind.
