What springs offer seat pressures of 130-150 lbs?
Either at stock valve installed height, or shimmed up as long as they can still handle .610-.630 lift safely.
The Crane duals seem to be weak on the seat, so looks like best to go with a .030 shim or so. That takes there limit to what .615 lift?
918s are pretty good, but am more comfortable with a dual.
What is stock installed height?
Comp 977, 978, what else is out there?
Would you be wary of running two different springs, one of the intake and one on the exhaust?
