Removed jet chip and car is running like CRAP..HELP!
I took out the jet chip today...figured I'd have enough time to let it relearn the normal/stock fuel curves...well, first after plugging the ECU back in it wouldnt start..???? ....then I figured out that I hadnt tighted the ecu in right so I got the connection right being extra careful not to over tighten the ecu and hooked my battery back up and it started but felt like it had thrown a rod or something..I mean it's running ROUGH spittering and sputtering and backfiring I tried to drive it and it feels like it's got no power..I mean it barley get's down the street...did I fock something up?
Then I reset the ECU via the fuses tried driving it again and it was worse...am I just being to anxious, does it need more time to reset the fuel curves or did I mis-sequence the removal somehow? All I know is it as running fine with the chip and now it's running like ****....I need some input here...
Thanks,
Mike
Thanks,
Mike
