Borla true dual (pics)
1 Post
These are some quick pics that I snapped. They were using a cheap disposable, but you get the idea. I'll have some better ones later in the week.
The setup is:
2.5" Tubing.. slip-fit at the headers and stainless steel band clamps.
2.5" mandrel x-pipe- slip-fit coming out of the x to allow the exhaust to be taken apart easily.
2.5" center in/out Borla XR-1 Sportsman mufflers (40942) [3" is (40943)]
Pics can be seen here..Borla Duals
The setup is:
1 Post
Originally Posted by NOBR8KSS
Looks good...ground clearance looks pretty decent too. I assume with those mufflers that you are remaining at stock ride height?
Originally Posted by Z28Venom
Yea.. I'm gonna keep stock height for now, but I have plans to mod the rear floor and tuck the mufflers up about 2.5"... So then I'll be able to run a Pro-Kit when the time comes..
1 Post
Originally Posted by ineedtorque
I downloaded the video of your car and it sounds so dope. Where did you buy the material for the exhaust at?! Im probably getting pacesetters and id like to get the same true dual as you because it sounds mean as hell.
45 degree bends from CarQuest.. but they aren't mandrel..
3"-2.5" Reducers - CarQuest
6' of 2.5" tubing - Midas
Welder - provided at local military hobby shop
Hangers - Checkers
Total I spent around $400...
