thick gasket for .055 milled heads
Old 03-18-2003, 07:11 AM
robertbartsch's Avatar
Default thick gasket for .055 milled heads
...my new heads are milled .055, and I am considering the TR reverse split 230/224, 114, with a 560 lift...
....as there may be piston/valve clearance problems, can I order a thick head gasket than stock to avoid having to flycut the pistons?
Who sell these?
Old 03-18-2003, 10:09 AM
modsdone's Avatar
Default Re: thick gasket for .055 milled heads
sent a pm.
Old 03-18-2003, 10:24 AM
LS1Tech Sponsor
Slowhawk's Avatar
If your running bigger valves I would say you have to flycut the pistons.It is not very hard.Isky sells a kit that you do in the car.
