Going from a Vig 2800 to a Yank SS 3600 help?
I like the way the car drives the way it is but would like more stall than what I have. The Vig 2800 stalls at 3200 on motor and when I spray it goes close to 4000. I was told I wanted a tighter converter since I am spraying the car? Would I be wasting my money going with this converter? The car hooks really well on the street and always ran good numbers but I am getting the fever of wanting more stall.
1 Post
I take it your spraying 100 Shot NX by your sig. If it were me I'd step on up to the SS4000 anymore spray than that I'd back down to the SS3800. That is if you are wanting the SS series converter. Me personally I'd be going with the PT series or a TCI 4000 converter. JMHO.
1 Post
The SS line seems aight. I had a SS3800 and switched to the PT4000. There is no comparison between the two. If your wanting the best of both worlds you'll be lacking N/A with the SS series. Go with a PT for best possible n/a times. Make sure if you buy a used converter that it is without problems and it is probably best to send it in to get refreshed. Might as well restall it to a 4000 at the same time.
Originally Posted by Ragtop 99
Why not try restalling to a vig 3200 first and seeing how that does. Are you within the free restall period?
That is great 1.6 times with bolt ons. I have cut a best of 1.65 60' on the spray. I also live in Florida which only has a few good tracks and they are a drive to get to. Orlando Spinworld is the closest track and traction is hard to find there.
I thought about going to the 342 gear but I thought it would be that much harder on the weak 10 bolt rear and then have traction issues? When the rear brakes I will put in a 12 bolt.
Thanks for all the great replys guys.
