Ikeep hitting the rev limiter almost every other run,why???
car ran good except for this problem. i have the hpp rev limiter set the last time at 6500, that run was 12.3 , run before that i hit the limiter???? mods to car:slplt's 3.73,sy 3500,lca sfc,cai.almost every other run i hit the limiter. times were 12.40 not hit
12.34 not hit
12.70 not hit but spun off the line
13.20 hit limiter
then two runs i hit limiter and backed off the run
12.34 not hit
13.20 hit limiter
Re: Ikeep hitting the rev limiter almost every other run,why???
Why the Hypertech program does not work I don't know. I had the same problem with mine when i install 3:73 gears. I used to run my car in D not overdrive because I always ran a little faster in this gear. After hitting the rev limiter with the gear installed as mentioned above, I finally just did the Hpertech install with the performance tunning and no other adjustments and drove the car in overdrive which gave me more RPM range and ran faster times. It would still hit the rev limiter, but I still ran some respectable ET's at the local track. Finally, I did a custom tune which eliminated the problem. Hopes this helps. Good luck. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
stop raising the limiter and lowering the shift points on that shift.. im guessing its the 2-3 shift? i had to lower my shift -3 on that, and i have my limiter raised to 6300.. i wouldnt go above 6300 unles you have internal work done... to risky
just lower the shift points on that shift one by one till you dont hit it <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
thanks guys. if it dosen't rain on wed. were going to e-town I'll try lowering the 2-3 shift and see what happens, hopefully no limiter and faster times. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Ed Wright can take care of all your present problems & a few more that might spring up.... WJ. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
