Question about Menzerna Intensive Polish with PC DA buffer
Well, I broke down the other day and bought a Porter-Cable 7336SP. I bought some Meguiar's Swirl Remover No.9 and got some really impressive results with it and the PC using only the polishing pad that came with the PC. But I still have some swirls, so I ordered a DA pad kit and some Menzerna IP from Autopia. Am I right in thinking that the IP will remove more swirls than the Meguiar's No.9 or no? And what speed setting do you guys use with the IP?
Just a note, the PC buffer is the best imvestment I have made for detailing. It makes even just waxing so much easier and the results are outstanding. I would say I removed or "hid" 90% of the swirls and spiderwebs just doing a once-over with the buffer and some NXT- so much more than I could ever do just hand-waxing. But my goal is to remove the swirls instead of just hiding them so I am hoping the IP will do the trick.
i usually use the IP with a CMA orange pad @6. The IP will remove more than #9 cause that has oils in it so stick with the menzerna it will remove what most common light swirls if you apply moderate pressure you can remove more just take time and work in sections
