Paging project DRAGULA (PSJ)...Friday was good weather!
I heard from a few that Friday night got them some new MPH bests.
Did your MPH go up with the new tuning and setup on the car? Share the difference in MPH + or - if you don't want to give up your trap speeds.
I'm just curious weather BV performance has got the big injector cars worked out yet. Was it worth it from a performance standpoint?
Re: Paging project DRAGULA (PSJ)...Friday was good weather!
Well, give us a race report. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> As much as I've read about "dragula" I'd like to see the progress reports.
What gives?
What gives?
Micky Thompson doesn't make a tire in that size.
You must have your numbers wrong. OR....I don't have an updated jobber list.
I guess we'll see what she does on the big tire then....definitely more room left on the 60 foot.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>Friday I ran at GLD on the MH Racemaster 275-60-15's. Even at 14 psi I could only get a 1.61 with them. Last time as at GLD I also cut a 1.61 on the MH's; I also cut 1.65's on my old 26x11.5x15 ET Streets.
So I've decided to go to 28x10x15 ET Drags.
My best times in Chicagoland have all been at US41, but I will not be down there for a couple more weeks until I bang out some stuff on the car.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How bad was it spinning? I've spun to a 1.54 and several high 1.5's, but for a 1.65 I would have to spin my *** off.
Why were you running on these tires and not a true slick?
What convertor did you switch to after the BG race?
Arent you running a 3.90 gear?
Just curious <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
LS1Tech Co-Founder
BG/NFRA I had a Yank 4400 but it was stalling to 5300 because of all the tq of the new motor. Car would not hook a 28x9x15 ET Drag at BG because of the huge stall. I sent it back and now it's really great on the street but too tight at the track.
Car has a 4.10 in it.
OH, and in Jan/02 I went 1.51 and dead hooked. A few hours later I went 1.53-15.6's and I spun about 5 feet on those runs. I can only guess that a 1.61-1.65 for me now feels like I am spinning for a car length.
<small>[ April 29, 2002, 03:29 PM: Message edited by: Pro Stock John ]</small>
John,
Just a heads up. I just got around to installing the colonel converter in my car. haven't tested it yet. I have a whole new tranny being built so probably in a month or ( don't anticipate more than two ) the colonel's old converter will be up for sale. If you might be interested give me a buzz, stephen can give you even more details on how it ran.
Larry
Larry
He's talking about M&H, not Mickey Thompson. M&H have been making race slicks a long time, and recently they've gotten really really popular with the fwd import crowd. Some of thier tires wrinkle very well it seems.
This what you're running John?
<img src="http://www.nitroz.se/arlanda/images/hb10.GIF" alt="" />
J.
J.
LS1Tech Co-Founder
Hey Project Slugula:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I could only get a 1.61</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Don't feel bad, see my signature <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tony
Tony
I still want to know where the 200# of lead is hidden in John's car. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
LS1Tech Co-Founder
Pain, I'll call you in a little...
Crazy, I have M&H Racemaster, full treaded 275-60-15 DOT bias ply. They have a full tread pattern all the way across not just 3-5 grooves in them.
Terry, I went from 419rwhp unlocked to 450rwhp unlocked.
I talked to Mike Senia @ Yank and we feel that my 3800-4100TP-E is probably a bit too tight for my 10 second NA goals.
I talked to Nick @ ARE today too and he's thinking I need to loosen up the converter. May try locking up the converter to see how many mph it picks up. I still have my manual l/u switch.
LS1Tech Co-Founder
Hey John, I stopped by MTI today. My heads are done and the block is being assembled. I might have the car running by this weekend.
Are you gonna let me get 10s first? I've been down over 3 months!
Slacker <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tony
Tony
LS1Tech Co-Founder
I've been to the track twice since they opened, which was less than four weeks ago. I have 10 runs on the car.
I haven't hooked better than a 1.61 on the MH's and a 1.65 on the ET Streets.
I guess I go get those 28's on Thursday so I can run this weekend.
I'm at that point where some mad weight reduction will take place just to run a #.
On pump gas of course... Will yoooooo be able to run on pump gas? <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
John that is a really big RWHP jump! What did the MPH do?
I'm still a big confused by your power level, clearly something isn't right with the motor. Most of the 421ci+ motors are putting out 475-525rwhp. Maybe there is a rocker issue or something? With that much torque and 4.10s you should not need any more than a 4000rpm stall. I probably have 100#/ft less torque than you and leave just fine with a stock TP4400. The other strange thing is your weight. I still don't understand how you wound up at 3750. You are a full 350# heavier than my 2001 Z28! How is that possible?!?
LS1Tech Co-Founder
Most of the MTI 422+ cars are M6's and I have not locked up the converter to see how much I would gain. PaiN's car is a A4/422ci but has LS6 heads, more compression too.
I'm wondering if my TP-E 3800 is too luggy on the shifts for an NA car I have like very little shift extension. I make 430rwhp by 4800 rpms FWIW.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I make 430rwhp by 4800 rpms FWIW. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nice info <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
For comparison, WeatherGuy made ~445-450 at 4800. He has an M6, R1 cam with LS6 heads though a 12 bolt FWIW. Sounds like you are on the right track up to that point.
J.
edit-that was the only 422 dyno I could find right off hand.
<small>[ April 29, 2002, 10:00 PM: Message edited by: Crazyquik ]</small>
J.
LS1Tech Co-Founder
2000 11.76@114mph H/C/3.50/PI3600
2001 11.15@120mph 422ci iron/4.10/Yank3800
Fri went 11.3 spinning on 1.61-1.64's on treaded bias plys... raceweight was probably around 3750.
I'm in process of getting 28x10x15 Hoosier Drags, but I wiill not run the car until I do some weight reduction, I just added dual 3" stainless mufflers...
