Sponsored by: DashLynx
Need instruction for thunder coil relocation kit
Old 06-23-2004, 08:27 PM
theblur98ss's Avatar
Default Need instruction for thunder coil relocation kit
I got a thunder coil relocation kit but I don't have any instructions. Do I just pull the cowl out and screw the coils to the cowl and then put it back in and hook them up?
Old 06-23-2004, 08:40 PM
XtinctHawk02's Avatar
Pm "wild thing". His Dad and him did this reloaction kit.
I'm sure he would give you some pointers on installation.
Old 06-23-2004, 08:57 PM
max's dad's Avatar
remove wipers: I think it is a 13mm bolt on each wiper arm.
remove cowl: a bunch of push rivets
you'll have to drill two holes per side to mount the brackets. It will be obvious where to drill once you're there.
good luck
Quick Reply: Need instruction for thunder coil relocation kit
