Small problem with cold starting
Old 06-25-2004, 02:32 AM
Blacker's Avatar
Default Small problem with cold starting
I have read and tried different techniques to help cold starting. I have tried different values for the VE Table in the 400-1,200 range. I lowered the values in the Crank VE table as well. My problem is when the car is first started, it goes to ~1,200rpm and drops down to 400rpm and will stall. Now, if I keep the rpms at 1K for a few seconds after starting, it is fine. Also, the hot starts are perfect and I have no surging anywhere. I had the VE table adjusted down to 50%, 55% and 60% for the 400-1200 range. Still did not help. The Crank VE Table is at 75% right now. My cam is the F10 (228/228 0.575/0.575 114LSA) and I have stock heads. I also have my IFR table at 90% and the MAF Table is stock. Any suggestions?
Old 06-25-2004, 06:36 AM
Billiumss's Avatar
Auto or M6 car?
I have a very similair cam 230 230 .575 .575 114 lsa
I have my Main VE set to 60 65 70 and did the whole column and cold and hot start are fine.
Put your Crank VE back to stock.
Did you drill out the TB any? I went 2 drill sizes bigger.
Did you adjust your IAC tables?
Old 06-25-2004, 07:21 AM
Blacker's Avatar
Auto
I drilled the TB to 7/32"
I used NoGo's recommendations so far and still have to help it along for 3 seconds after start up.( http://www.ls1tuning.com/iboard/index.php?showtopic=9 )
Old 06-25-2004, 08:19 AM
Black02SS's Avatar
I have this same problem with my FM11. Only difference is I am a M6.
Old 06-25-2004, 10:33 PM
ataylors's Avatar
have you added timing at 1200rpm and down??? I added 3* up to 800 and 2* at 1200 because it pinged some when taking off on a hill with the M6
ataylors's Avatar
Also check your desired idle vs ECT
Old 06-25-2004, 11:10 PM
Blacker's Avatar
I haven't added timing. I have the idle set to 900rpm at start-up and once over 132*, it is set to 800rpm.
Old 06-25-2004, 11:21 PM
ataylors's Avatar
I have my cold idles a bit higher so it will warm up quicker then to 850 when warm. The timing really did the trick for me. I am at 224/224 114*
Old 06-26-2004, 09:26 AM
Another_User's Avatar
If you are just trying to do a hack job to get it running the best thing to do is scale you VE 60%, 80%, 90%, add 2 degrees of timing up to (and including) 1200 rpms, and get your IAC count down to about 30ish. If you do that it should eliminate everything except WOT problems and surge at cruising speeds.
Old 06-29-2004, 06:55 PM
Blacker's Avatar
I set the IFR Table back to stock and used my new VE Table. The cold and hot starts are perfect and now need to fine tune some areas within the VE Table. My LTrims are ~+5 and no surging at any rpm.
