How High Is It Safe To Spin Motor??
How high would it be safe to spin a stock bottom end LS1??
I'm trying to get down my setup and where I'd like to cross the lights at RPM wise, so I need to know this.
car is a totally stock bottom end 346 LS1.
Wasn't sure where to put this post, so if its in the wrong section, sorry moderators <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Sean
A.R.T 98 Z28-Silver
2002 Durango SLT-Silver
Sean
A.R.T 98 Z28-Silver
Re: How High Is It Safe To Spin Motor??
Some say 6800 RPM's some have gone over 7000 but have broke. I'm stoping at 6800 RPM's on my to play it safe untill I get forged parts.
LS1Tech Co-Founder
There are lot of folks out there buzzing their setups to 6500-6600 rpms.
I'd would go no higher than 6800 rpms as well.
I'd run the oil a little over. LS1's have an oil system like the LT5, the oil first goes to the cylinder heads. So I like to run a bit over, as much as 1/2 a quart over. I don't think we are likely see any cavitation from running too much oil, plus with our factory pcv systems, you can end up using 1/2 a quart after 20 passes at the track.
I'd give serious consideration to running a heavier weight oil or a higher quality oil if you are trying to avoid needing to pull the motor at the end of the racing season.
Locally the motors that have come apart have had stretched rod bolts.
I am running 10w40, 1/2 over, and the car sees 6600 rpms every time I drive it.
I spin mine to 6500 most of the time, thats where I peak in the powerband...I use mobil 1 synthetic 5w30 and always watch the oil, I try to keep it full as much as I can...the motor current has 11,000 miles on it, and from here on out its only going to get beat on harder, I think I will have enough $$ then by the time it takes a dump.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
