What is wrong with my idle
Old 06-25-2004, 09:34 PM
SS125's Avatar
Default What is wrong with my idle
I had the tsp 231/237 cam and pp ls6 heads installed a couple of weeks ago. When I got it the car would start, idle for sh#t to the point at times it would die and when you slowed down it would do the same thing, finally got the p1010 code. Took the car back over to APE this week. Kirk played with LS1edit and drilled the tb hole to 7/64. Car ran fine while at his shop. Started fine, idled fine. Now it seems to have reverted somewhat to it's old self. Car idles fine after it warms up, doesn't die when coming to a stop. But, when you first start the car either cold or hot, it doesn't want to idle at all. What can I do to get the car when you start it, it idles as good as it does when your setting at a red light later on. This is the only problem I've got. IT acts like it's just getting gobs of fuel at startup and is running pig rich. Does anybody have any ideas as to what to do about this?
Old 06-25-2004, 10:14 PM
ataylors's Avatar
Have you tried asking APE about it?? Since they already made changes they would have a jump start on it. Sounds like they may need to recenter the IAC.
Old 06-26-2004, 07:44 AM
merlinsrealm's Avatar
I am having the same issue with my 232/236 cam.....I am trying to have the issue worked out today...I will post if I find out anything....
Eric
Old 06-26-2004, 01:55 PM
Cheatin' Chad's Avatar
tothetop
Old 06-26-2004, 06:56 PM
Black02SS's Avatar
I have similar issues with my setup as well. Just manily the cold starts suck ***.
