where to find wiring diagram?
i'm about to put some subs in my truck, but i need to know what wires to hook the RCA converter to. Any help would be appreciated.
Search, dude.... this was the eighth trread down...
https://ls1tech.com/forums/wiring-stereo-electronics/185586-problem-output-converter.html
Sorry, I thought you were posting about your T/A. I believe that the color codes would be the same though. All GM vehicles within 5 years of one another usually share the same harness colors.
Deranged Rat Fink
1 Post
snootch is correct , the only variation will be the delco bose system which use use a shielded braid instead of one of the negatives , even the amplified moonsoon is the same .
