alright guys got some codes.
Well the first set is the rear 02's. I had an off road y, and reverted back to stock manifolds and stock y. Cleared the pcm and i'm getting the same result as if the cats were gone. rear 2 bank 1 and 2.
Then i am getting a multiple missfire code, a lean code, and a bad air sensor voltage code. Would this have anything to do with a dirty or broken maf. thanks.
Everything seems to run fine, but sometimes at idle, it keeps searching for an idle, vibrates and so on. Plug wires and so on are all good, if that was the case i would be missing alot of power, and it seems to be all there.
[QUOTE=redz_02]no tuning, was running qtp full length headers and so on then replaced them with the stock manifolds, took everything back to stock b/c it just doesn't seem practical to make a drag car out of something i pay 400 bucks a month on. So i found a chasi for 400 bucks, just need to get this thing in top shape to sell it.
