Spent the day (!) dieting
I went picking through the car this weekend looking for things to remove that won't affect my streetability (much). Here is what I came up with:
AC (28#, not 40# like others say)
AIR pipes/solenoid (2#)
Wet N2O system (2#)
Pass side airbag (16#)
Pass side seatbelt (3#)
Pass side sun visor (1#)
Glove box (4#)
Driver side kick panel (4#)
Driver side radiator fan (4#)
Grand total: ~65#s.
It's getting harder and harder to remove weight on this car. I'd like to do carpet and back seat cushions, but I really like the way the car looks with both in. I don't want to part with my fan/heater either. I'm thinking side crash bars might be next (15#?).
One of my next "minor" mods is probably going to be larger headers, and a quiet exhaust setup that I can easily remove at the track. There is another 45# of weight there and maybe 5-10rwhp with the right set of headers. I need to get on a scale to verify, but doing the math my race weight should come down to 3320# now (with catback) with a mostly empty gas tank.
<small>[ May 12, 2002, 06:30 PM: Message edited by: Terry Burger ]</small>
Wet N2O system (2#)
Glove box (4#)
Grand total: ~65#s.
Re: Spent the day (!) dieting
Hey terry, how much do you weigh?? I weighed my car yesterday and it came in at 3270 and you have more removed than me. I'm only 140 though so that could be where the differnce is.
I come in at 195 with my helmet, I'm going to get that down to 180 soon. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I've removed a lot of weight, but I also have a 5-pt cage.
LS1Tech Co-Founder
I did a plug change today, but also removed:
-front swaybar brackets
-cruise control box and cable
-front bumper support, washer fluid container
Nose looks like it sits up higher and the car weight transfers SOPT better.
I briefly removed a foglite (98 Formula) but it looked horrid and I think they are a few ounces each LOL.
I will remove most of the carpeting a la Chris Pippy mod, and some obvious stuff out back before I hit the track again.
All can easily remove up front now is P/S and ABS control. Nothing left.
John how much weight is the cruise control box/cable, 5#? Take long to remove? Try a Meziere electric water pump. It saves 8# and was worth a whole .1ths for me. Don't worry about a thermo, you don't need one. I even figured out how to hook it up to my heater box. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
The door bars are 8lbs each. but a real pain to get out. I'm going to do the !cruise control and Dynabat this week. 15lbs more. Could I be under 3100? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
More of a pita than the airbag? I had to take the whole dash off to get that sucker. I felt bad not taking the heater box out while I had it apart. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
can you guys tell me how to remove the power steering, abs and the cruise control box...its bout all i got left up there. what size belt would i need with the ASP pulley after that? 51"?
Next time out i want both wheels off the ground instead of one <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Jerry
Jerry
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mine sitting up so high its given me another reason to get hals......lower back down where it belongs.
I removed my front fog lights and I though it look kind of cool.....but mione is black car and gave the whole front end kind of black out look.
What are you guys doing for carpet??? getting lightweight or simply removing the back padding. I just can't bring myself to remove the carpet completely....unless of course I tint my windows really dark then no one would know <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong>
getting the door bars out SUCKS!!! about 6lbs each. ive done the passenger airbag, not quite sure how to compare it to that job. guess they are both just a major PITA in thier own way
Terryble now has not only a JR Dragster but a REAL LEGIT RACE CAR
Cant bust on me anymore about my car Terry
Yours is GUTTED compaired ot mine now.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I still have power steering, a quiet exhaust, and a cd changer. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
LS1Tech Premium Sponsor
Damn, you guys are hardcore. My all-out '67 Chevy II drag car tipped the scales at 3,240# with a big-block and me in it. Besides, writing the check for the SS is still fresh in my mind. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> With that said, I did shed 24# by pulling the backseat w/ belts. I left the bottom cushions in place, though.
<small>[ May 13, 2002, 08:28 AM: Message edited by: Trevor D ]</small>
I am planning on removing foglights and cruise/AIR pump, sway bar brackets as well. That will be around 12-14#s or so. I am scared of removing my front bumper supports after witnessing that terrible crash a couple of weeks ago.
I am also thinking about buying a lightweight battery for use at the track only as well. That will be another 16 pounds at least.
Dont forget about allt he plastic **** underneath the wheel wells as well. That is another 5 pounds I think. (Not the air dam of course)
Terry AC out with Compressor and bracket out comes in at 47#'s on my scale at home. Might want to recheck that number and make sure you have everything out of the car <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
One word of advice with the "backhalf" of the carpet mod. When you cut the carpet, cut it only under the seats. I tried to get creative and cut it up along by the center console but it doesnt look that good. I am going to get some velcro for the floor and underside of the carpet at that point to help secure it a little better. Otherwise it works really really well and the carpet, all back panels, front and back seats add up to about 100 pounds.
Cheers,
Chris
Cheers,
Chris
Terry I'm not removing my power sterring pump.I wanna be able to drive the car with it when I'm not racing so its staying on the car.I dont know if I'm gonna pull the air bag either.The more I think about it the more I realize all I wanna do is go 10's a couple times and then the car will be put back to a nice 3.73'd,3200 stalled,quiet exhaust'd,17in wheel'd,Drag radial'd street car.
11.50's is fast and I can alway put a 100 shot on the car down the road.
By the way I have ALL of my stereo in place.
Gotta have music...
JS
Gotta have music...
JS
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Maybe 2001 got a lighter AC system? My compressor was 16#, the bracket/tensioner system 4#, the condensor 10#, and the piping and other stuff 2#. Where did you get 47# from?!?
How much does the back half carpet alone save, 10#?
fyi, my AC stuff out of my '98 weighed over 40 lb's also, can't remember exactly since it was 2 years ago.
I think it was 43 or 46lb's.
Mike
<small>[ May 13, 2002, 01:11 PM: Message edited by: mgreen ]</small>
Mike
I took ac off of my 98 the other night and it all came in at about 45lbs <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I weighed the condesnsor seperate..it weighed about 9 lbs then I weighed everything else in a garbage bag and that stuff cam in at close to 35.
Hope I didn't take off more than I should have <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
