28lb injectors on a 36lb injector tune????
I had a set of 36 or 37lb injectors with my old heads/cam setup and I recently put the car totally back to stock including my stock 28lb injectors, I didn't think the car would even run being tuned for those big injectors but it started right up and idles and drives pefrect The car has sat for about two months without the battery hooked up also. I dont know if that makes a difference or not.
So should I be worried about getting it tuned for these injectors or will be ok to drive like it is for a few days? I don't plan on running it hard and I dont hear and detonation right now but I just thought I would check to see what everyone here thinks.
thanks,
Sean
thanks,
Sean
