push rod length math
Old 06-27-2004, 10:55 PM
FirstGen's Avatar
Default push rod length math
Ok, so I have a 2002 6.0l LQ4 and since the only difference between the LQ4 and the LQ9 is the compression I want to mill the heads to recover this.
My question is with the 01 LS6 cam I have the base circle is .520 which is .030 smaller than the stock (.550) then I also want to mill the heads about .030 for higher compression. According to the articles on this forum, am I right that I want to run chome moly 7.35 length push rods?
Also can anyone tell me what compression I will have using rough math for this motor after shaving the heads?
Thanks for any input.
Old 06-28-2004, 01:21 PM
FirstGen's Avatar
anybody know?
Old 06-28-2004, 03:49 PM
1fastWS6's Avatar
Stock PR is 7.380".....
Your increasing the req'd PR length by going to a .030" smaller base circle cam, then decreasing the req'd length .030" by milling the heads. So the stock PR length is what you ideally need. The 7.400" will be .020" too long, and the 7.350"s will be .030" too short. The stock lifters can handle a small increase in preload.....get the 7.400's.
Do a search on the compression ratio question, there's a HUGE thread on that.
