Drag Racing Tech - th350 burnout box ?'s
View Full Version : th350 burnout box ?'s
ducati916
06-28-2004, 10:29 PM
with th350 and 3500 stall converter, i do like a 8 second burnout in the box. the tires break loose at about 3800, and if its in drive or 2nd it will hit second then first then second then back to first, so on. it wont stay in second in the burnout. also in that 8 second burnout the engine temp goes from 200 to 230 in 8 SECONDS................WHAT GIVES
Colonel
06-29-2004, 12:55 AM
Keep the selector in "1" during the burnout. You don't have enough power to pull 2nd during the burnout.
Try a 160 degree thermostat and lowered fan settings. Make sure you don't have any air in the system. You should also monitor your tranny temps. VERY important.
ducati916
06-29-2004, 08:22 PM
not enough power to pull second??? I dynoed 458 hp and 512 ft/lbs torque.....how much do you need to do second? i just dont want to burn up the trans or the motor. Still dont understand why the motor heats up 30 degress in 8 seconds.
silverTA
06-30-2004, 04:30 AM
i got TH350 and i do a longer burnout than 8 sec and i never had a temp proplem ,,
i go from first shift to secound back to first and then stage
Zo6Killer
06-30-2004, 05:52 AM
I just do my burnout in "D". Then again, thats behind the 327. hehe :devil:
GIZMO
06-30-2004, 07:29 AM
I start in first and shift to second and then third at about 5000 rpm. I then hold about 5500 in third until I see decent smoke from the tires and then release my line lock. You are probably not turning the tires fast enough causing them to grab and pull down the motor during the burn out.
You are also running your car kind of hot to make best power. I try to stage at about 140-150 for each pass.
Daren
