Drag Racing Tech
How to launch m6
Old 05-21-2002, 07:34 AM
White98Z's Avatar
Default How to launch m6
Yea i was wondering how i should launch my car the tires on the rear are 315/35/zr17 with all the mods in the sig
Old 05-23-2002, 03:50 AM
Judd's Avatar
Default Re: How to launch m6
I get my best 60 fts by slipping the clutch. Can't seem to find the perfect rpm for side stepping the clutch, it either bogs or it spins bad. Also have around 75-100 1/4 mile passes on the stock rear and haven't broke it yet, I think slipping it helps in that department. My best 60ft was somthing like a 1.90- could have been better as I was at a really sticky track but after all those passes and 25K miles at the time, the clutch was getting a bit wimpy and would slip whether I wanted it to or not. Average at Commerce Dragway,a track known for it's crappy starting pad was low 1.90s. BTW, averaged almost the same with stock Firehawks as I did with the BFG D.R.s. The BFGs were more consistant though.
Old 05-23-2002, 04:03 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
if the tires are stock, then i would slip it, as soon as you fell it start to plant then put your foot into it.
if those are nitto's heat'em up real good, then drop the clutch at say 3300rpm, if the track hooks well.(i am not responsible for any broken spider gears <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> )
be sure to load up the rear, that'll help it survive.
Old 05-28-2002, 02:33 PM
1WhiteWS6's Avatar
THe best way that I can launch my car is by tapping the gas between 3800 to 4500rpm's and slowly ride out the clutch. If your tires spin then push the clutch in a little bit more until they hook up.
