Patriot Shaft Mount Rocker Arm GP!!
Old 06-29-2004, 01:31 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default Patriot Shaft Mount Rocker Arm GP!!
Patriot now has their new shaft mount rocker arms in stock & ready to ship! Lets kick these things off right with a GP!! Retail pricing is $579.99!! (already 300+ less than other shaft mount rockers!!)
Pricing will be $529.99 for 1-4 orders
4+ will take off another $20!!!!
Terry can you repost some pics of the rockers!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 06-29-2004, 01:34 PM
Z06PSI's Avatar
dammit .... I just bought some comp cams rockers....
Old 06-29-2004, 09:13 PM
1fstTA's Avatar
ive already got these and believe me they are a top notch peice to say the least. very happy with mine.
Old 06-29-2004, 11:20 PM
95LS1TA's Avatar
Are they adjustable?
Old 06-30-2004, 09:12 PM
1fstTA's Avatar
yes they are adjustable.
Old 06-30-2004, 10:54 PM
BANDITSS's Avatar
will they require taller valve covers?
Old 07-02-2004, 03:51 AM
BOWTIE's Avatar
Where can we check these out??? Seems to good to be true.
Old 07-03-2004, 05:12 PM
95LS1TA's Avatar
Pics???????????
Old 07-03-2004, 06:04 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Here's the first thread I found in a search. It has a decent picture attached. Terry, could you post up some more pictures when you get a chance?
-Matt-
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 07-04-2004, 12:15 PM
BTL FED's Avatar
-Matt-
Where is the link?
Old 07-04-2004, 01:15 PM
OOPS! Forgot the link.
https://ls1tech.com/forums/showthrea...=patriot+shaft
-Matt-
__________________
Old 07-04-2004, 02:09 PM
BTL FED's Avatar
What length pushrods are you running, and did you have to modify the pushrod holes?
Old 07-04-2004, 05:17 PM
1fstTA's Avatar
Im running a 7.200 but Ive heard from terry that some are running 7.150. yes the pushrod holes do need modified.
Old 07-04-2004, 11:52 PM
99BackNBlackZ28's Avatar
Have these rocker arms been tested thoroughly? If so for how long & on how many cars?
Don't want to be a guinea-pig for Patriot again....
Old 07-07-2004, 04:56 PM
Back in the staging lane
Beeler422's Avatar
I am interested in these as well. Could someone explain why the pushrod holes have to be modified and what needs to be done.
Old 07-08-2004, 06:19 AM
BTL FED's Avatar
The pushrod holes in the head just need to be elongated a little, because of where the rocker is and the shorter pushrod causes more movement of the pushrods, it is really easy to do espically with the heads off
Quick Reply: Patriot Shaft Mount Rocker Arm GP!!
