Torque Specs for Crank Bolt?
Old 06-29-2004, 04:40 PM
retsell's Avatar
Default Torque Specs for Crank Bolt?
anyone know what the torque specs on the crank bolt are?
Old 06-29-2004, 05:04 PM
felton316's Avatar
33 ft-lbs, then 130*.
Old 06-29-2004, 05:40 PM
2xLS1's Avatar
Install the old crank bolt and tighten to 250 FT/LBS of torque.
Remove old bolt.
Install a new bolt and tighten to 37 FT/LBS of torque, then rotate the bolt an additional 140 degrees.
This is for the stock pulley. The instructions that come with the ASP pulley say 120 degrees.
Old 06-30-2004, 01:44 AM
pekkaz's Avatar
In practice just torque as hard as you can ( with new bolt after seating the pulley). Last time I didn't even bother with torgue and degrees just pulled it as tight as I could. My experience is I'm able to pull 100-110 degrees after initial torque.
Old 06-30-2004, 06:30 PM
retsell's Avatar
That is exactly what we did. That is the most I could do.
Old 06-30-2004, 10:31 PM
68birdls1's Avatar
where did yall get your bolts from?
Old 07-01-2004, 10:00 AM
VSGLS1's Avatar
Dealer. It is $4.xx.
Old 07-01-2004, 05:03 PM
felton316's Avatar
I got mine from ARP.
Quick Reply: Torque Specs for Crank Bolt?
