Harland Sharp rocker install questions...
Old 06-29-2004, 08:47 PM
SPANKY LS1's Avatar
Default Harland Sharp rocker install questions...
My heads are milled ~.005, my pushrods are 7.400, and I am using Comp 978 springs and OEM lifters. When installing the HS rockers, do I just torque them to 22ft/lbs like stock, or do I have to check anything? Thanks, Shawn
Old 06-30-2004, 07:44 AM
JoeyGC5's Avatar
ttt, curious as well
Old 06-30-2004, 10:03 AM
Nasty N8's Avatar
You should be OK to just bolt them down and go. But just to be sure I would do a quick check on one cyl to see where you are.
Nate
